Google RCS on iOS
Google RCS on iOS
Hello everyone.
Got a question and would like get to know when in Orange will be available Google RCS on iOS 18.x and above.
Peace
Yuma
11 ODPOW. 11
  • 2597
  • 11661
  • 102
Google RCS on iOS
Hi @Yuma, there are plans, but no specific date is known.
There is an idea for it here: Włączenie obsługi RCS dla telefonów z iOS 18 - Nasz Orange - 406719
Something more Rozwiązano: RCS w iOS 18 Public Beta - Nasz Orange - 401373
And information from the Orange spokesman:
Wojtek Jabczyński w serwisie X: „Wczoraj pytaliście i temat wygląda tak, że po udostępnieniu #iOS18 ...
It's in Polish but I think you can translate it and it's a confirmation of what I wrote - you have to wait.
Google RCS on iOS
Thanks for these hints. Maybe you know is there any chance to use RCS in some kind of port app or something to have it?
  • 2597
  • 11661
  • 102
Google RCS on iOS
Unfortunately not, because this service doesn't depend only on the application itself but on the mobile operator's support of this service also.
In Poland, no mobile operator can currently work with RCS on iPhones.
Google RCS on iOS
Its sad, thanks anyway
  • 2597
  • 11661
  • 102
Google RCS on iOS
You can use a workaround which I think will not satisfy you, but:
- on Android RCS works,
- you can use another messenger with e2e encryption,
- old ones compatible with all devices SMS 😉
At this moment, we have to wait for information about the availability of RCS, but we do not know at what stage the work is.
Google RCS on iOS
main problem is that some of my family and friends using only android devices with msgs by RCS while it works they are not going switch to comunicators
the other issue is that rate from poland to japan sms costs alot
  • 2597
  • 11661
  • 102
Google RCS on iOS
I understand. Unfortunately, in this case, the solution is to make some concessions and find a common communication channel.
I hope that RCS will soon be available on iOS in Orange.
  • 10281
  • 43276
  • 358
Google RCS on iOS
@Yuma
There are also other msg apps which work well on both OSes, like WhatsApp. My wife actually uses it on iOS to communicate with our Japanese friend.
  • 2597
  • 11661
  • 102
Google RCS on iOS
@j131napisał(-a)
@Yuma
But the case is:
@Yumanapisał(-a)
