Poor speed and lte signal in Piasecznie, ul. Graniczna
  • 12
Very poor speed of Internet connection in the Day time in Piasecznie, ul. Graniczna. In the night and early morning speed is ok.
6 ODPOW. 6
  • 10125
  • 42649
  • 351
@JulKa7napisał(-a)
And your question is?
  • 12
How can i use mobile Internet in this location without changing operator?
  • 10125
  • 42649
  • 351
@JulKa7
You can't...
PS. Changing the operator may not help, either. But of course you have to experiment and choose the best option.
  • 12
@j131napisał(-a)
@JulKa7
You can't...
Play is ok here, thanks
  • 22145
  • 65921
@JulKa7 mobile internet does not guarantee a constant speed. Your description shows that the transmitter is overloaded during the day, which makes the internet work worse. You can report to the operator, perhaps consider relieving the transmitter.
  • 16344
  • 68458
  • 883
@JulKa7 on a smartphone or on a mobile modem?
