Neofon jako trunk FreePBX
Witam, dostałem z infolinii login i hasło do telefonu VOiP [email protected]  i hasło.
w FreePBX wpisuje te dane do trunka i dostaje taką informację zwrotną:
[2025-10-17 16:46:20] WARNING[70097] res_pjsip_outbound_registration.c: 403 Forbidden fatal response received from 'sip:neofon.tp.pl:5060' on registration attempt to 'sip:[email protected]:5060', retrying in '30' seconds
[2025-10-17 16:46:46] WARNING[322803] res_pjsip_outbound_authenticator_digest.c: noendpoint:83.0.8.193: No auth objects matching realm/algorithm(s) '' from challenge found.
[2025-10-17 16:46:50] WARNING[41162] res_pjsip_outbound_registration.c: 403 Forbidden fatal response received from 'sip:neofon.tp.pl:5060' on registration attempt to 'sip:[email protected]:5060', retrying in '30' seconds
[2025-10-17 16:47:20] WARNING[41162] res_pjsip_outbound_registration.c: 403 Forbidden fatal response received from 'sip:neofon.tp.pl:5060' on registration attempt to 'sip:[email protected]:5060', retrying in '30' seconds
[2025-10-17 16:47:46] WARNING[70097] res_pjsip_outbound_authenticator_digest.c: noendpoint:83.0.8.193: No auth objects matching realm/algorithm(s) '' from challenge found.
[2025-10-17 16:47:51] WARNING[134546] res_pjsip_outbound_registration.c: 403 Forbidden fatal response received from 'sip:neofon.tp.pl:5060' on registration attempt to 'sip:[email protected]:5060', retrying in '30' seconds
[2025-10-17 16:48:21] WARNING[134546] res_pjsip_outbound_registration.c: 403 Forbidden fatal response received from 'sip:neofon.tp.pl:5060' on registration attempt to 'sip:[email protected]:5060', retrying in '30' seconds
[2025-10-17 16:48:46] WARNING[322803] res_pjsip_outbound_authenticator_digest.c: noendpoint:83.0.8.193: No auth objects matching realm/algorithm(s) '' from challenge found.
[2025-10-17 16:48:51] WARNING[41162] res_pjsip_outbound_registration.c: 403 Forbidden fatal response received from 'sip:neofon.tp.pl:5060' on registration attempt to 'sip:[email protected]:5060', retrying in '30' seconds
[2025-10-17 16:49:21] WARNING[41162] res_pjsip_outbound_registration.c: 403 Forbidden fatal response received from 'sip:neofon.tp.pl:5060' on registration attempt to 'sip:[email protected]:5060', retrying in '30' seconds
Login wpisuję z końcówką a, b, c, bez. Nie ma znaczenia cały czas jest rejected. Hasło 2 razy wysyłali mi nowe. Na zoiper to samo, na microsip też. Czy ktoś może mi pomóc?
  • 32396
  • 41510
Tu jest ok.
Podejrzewam, że problem jest z błędnym resetem hasła do neofonu.
Zapytaj na czacie lub infolinii czy mogą Ci wykonać "reset hasła" w systemie a nie przez sms. To czasem jest trudne...
12 ODPOW. 12
Ten, co wybrał Psikus ;)
  • 10362
  • 43708
  • 360
Nie znam FreePBX, ale Zoiper ma pokręconą konfigurację i tez nie mogłem na nim tego ustawić. Spróbuj czegoś prostszego na początek, jak Mizudroid albo Portsip. Starsze androidy obsługiwały to na natywnym dialerze (do 11 włacznie). Jednak każdy klient SIP powinien być OK. U mnie działa na kilku androidach, okazjonalnie na iPhone i na stałe na bramce CISCO ATA -192. Bez większych problemów. W logach sporo dziwnych rzeczy się pojawia, ale rejestracja generalnie przechodzi i działa. Uwaga: każde wygenerowanie hasła przez SMS oczywiście kasuje stare, a wielokrotne błędne logowania blokują serwer. Trzeba to konfigurować ostrożnie.
  • 32396
  • 41510
Pokaż.reszte ustawień w jakiejś częściowo zanimizowanj formie
W załączniku zrzuty ekranu konfiguracji pjsip.
CleanShot 2025-10-17 at 19.42.51@2x.pngCleanShot 2025-10-17 at 19.40.16@2x.pngCleanShot 2025-10-17 at 19.40.46@2x.png
  • 32396
  • 41510
Tu jest ok.
Zostało złożone zgłoszenie do techników, zobaczymy co poradzą.
  • 10362
  • 43708
  • 360
Myślę że nic nie poradzą. Hasło pewnie się rozjechało. Trzeba wszystkie urządzenia odłączyć, hasło zresetować jeszcze raz i zacząć konfigurację na jednym urządzeniu, najlepiej od czegoś prostego (może starty android 11?). A, no i na Funboksie powinno działać. Jeśli na nim działa, to konto jest sprawne, ale jeśli nawet na nim nie działa, to faktycznie sprawa do zgłoszenia technicznego.
Pan ze zgłoszenia do mnie dzwonił, na maila wysłał nowe hasło które zadziałało. Jeszcze warto dodać że nie działa już login z dopiskiem na końcu np. [email protected] do programu trzeba wpisać bez dopisku.
Problemy z Neofon i FreePBX
Po walce z obsługą orange w końcu dostałem działające hasło, lecz teraz pojawia się problem, że odbieram połączenia lecz czasem mogę je wykonywać, a czasem nie, a czasem to będzie jeden sygnał, telefon na który dzwonie zadzwoni a za chwile freepbx powie mi w słuchawce że wszystkie numery wewnętrzne są zajęte.
Pojawia mi się w logach takie coś:
[2025-10-20 17:21:27] WARNING[33572]: res_pjsip_outbound_authenticator_digest.c:577 digest_create_request_with_auth: noendpoint:83.0.8.193: No auth objects matching realm/algorithm(s) '' from challenge found.
____________________
*Scaliłem dwa wątki w jeden - moderator Wojciech.
  • 10362
  • 43708
  • 360
Mów za siebie. U mnie działa login z dopiskiem od lat bez zmian.
