Grodzisk Mazowiecki - jakość sieci LTE
Hej, dziś pierwszy dzień z Orange w Grodzisku Mazowieckim, pierwsze wrażenie
słabo to mało powiedziane, czy jest ktoś z Grodziska kto mógłby podzielić się wrażeniami.
Speedtest orange nie daje rady
C:\Users\Jacek>ping 8.8.8.8 -t
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=3124ms TTL=116
Reply from 8.8.8.8: bytes=32 time=3815ms TTL=116
Request timed out.
Request timed out.
Reply from 8.8.8.8: bytes=32 time=2503ms TTL=116
Reply from 8.8.8.8: bytes=32 time=3211ms TTL=116
Reply from 8.8.8.8: bytes=32 time=1658ms TTL=116
Reply from 8.8.8.8: bytes=32 time=305ms TTL=116
Reply from 8.8.8.8: bytes=32 time=948ms TTL=116
Reply from 8.8.8.8: bytes=32 time=535ms TTL=116
Reply from 8.8.8.8: bytes=32 time=2042ms TTL=116
Reply from 8.8.8.8: bytes=32 time=2755ms TTL=116
Reply from 8.8.8.8: bytes=32 time=995ms TTL=116
Reply from 8.8.8.8: bytes=32 time=335ms TTL=116
Reply from 8.8.8.8: bytes=32 time=1256ms TTL=116
Ping statistics for 8.8.8.8:
    Packets: Sent = 15, Received = 13, Lost = 2 (13% loss),
Approximate round trip times in milli-seconds:
    Minimum = 305ms, Maximum = 3815ms, Average = 1806ms
C:\Users\Jacek>ping nasz.orange.pl
Pinging exhhy82953.lithium.com [46.19.168.238] with 32 bytes of data:
Reply from 46.19.168.238: bytes=32 time=2563ms TTL=241
Reply from 46.19.168.238: bytes=32 time=1749ms TTL=241
Reply from 46.19.168.238: bytes=32 time=1738ms TTL=241
Request timed out.
Ping statistics for 46.19.168.238:
    Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
    Minimum = 1738ms, Maximum = 2563ms, Average = 2016ms
5 ODPOW. 5
  • 33182
  • 41361
Czy na pewno na LTE był test?
Router pokazuje LTE i przyzwoity sygnał 87%, sprawdzony bo śmigał u innego operatora bez problemu, dziś tylko podmiana karty SIM
  • IPv4 IPv6
  • Internet
  • Connection Type: 4G LTE /3G
  • Service Type: 4G
  • Network Name: Orange
  • Link Status: Established.
  • Connection Time: 06:38:18
  • IP Address: 10.78.242.6
  • Subnet Mask: 255.255.255.252
  • DNS Server: 194.204.159.1 , 194.204.152.34
  • Gateway: 10.78.242.5
  • 33182
  • 41361
A takie dnsy załadowały Ci się same czy je ręcznie ustawiałeś?
Automat ... nic ręcznie nie ustawiałem wyłącznie reset do fabryki aby nie zostały jakieś śmieci,  raczej muszę założyć ticketa ale jeszcze poobserwuję w czasie ....
  • 33182
  • 41361
Osobiście dla mnie one czasem zamulają. Lepiej jak możesz zmienić na google 8.8.8.8 i 8.8.4.4. A jak nic nie pomaga, to chyba zrób zgłoszenie na BOK. Sprawdź też czy nie masz wykorzystanego limitu danych.
