FunBox 3.0 i wariujący ping po WiFi
Mam FunBoxa 3.0 ze światłowodem. Po WiFI ping wygląda jak poniżej (i na 2.4 i na 5 GHz):
64 bytes from 192.168.1.1: icmp_seq=0 ttl=64 time=2.588 ms
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=3.365 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=1.767 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=7.192 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=8.509 ms
64 bytes from 192.168.1.1: icmp_seq=5 ttl=64 time=368.754 ms
64 bytes from 192.168.1.1: icmp_seq=6 ttl=64 time=438.708 ms
64 bytes from 192.168.1.1: icmp_seq=7 ttl=64 time=146.517 ms
64 bytes from 192.168.1.1: icmp_seq=8 ttl=64 time=606.287 ms
64 bytes from 192.168.1.1: icmp_seq=9 ttl=64 time=1.803 ms
64 bytes from 192.168.1.1: icmp_seq=10 ttl=64 time=14.935 ms
64 bytes from 192.168.1.1: icmp_seq=11 ttl=64 time=3.063 ms
64 bytes from 192.168.1.1: icmp_seq=12 ttl=64 time=2.724 ms
64 bytes from 192.168.1.1: icmp_seq=13 ttl=64 time=2.717 ms
64 bytes from 192.168.1.1: icmp_seq=14 ttl=64 time=2.915 ms
64 bytes from 192.168.1.1: icmp_seq=15 ttl=64 time=184.923 ms
64 bytes from 192.168.1.1: icmp_seq=16 ttl=64 time=260.133 ms
Request timeout for icmp_seq 17
64 bytes from 192.168.1.1: icmp_seq=17 ttl=64 time=1432.618 ms
64 bytes from 192.168.1.1: icmp_seq=18 ttl=64 time=428.331 ms
64 bytes from 192.168.1.1: icmp_seq=19 ttl=64 time=2.805 ms
64 bytes from 192.168.1.1: icmp_seq=20 ttl=64 time=2.276 ms
64 bytes from 192.168.1.1: icmp_seq=21 ttl=64 time=4.869 ms
64 bytes from 192.168.1.1: icmp_seq=22 ttl=64 time=5.237 ms
Czyli parę sekund OK i zawiecha. Jakiś pomysł co może być przyczyną?
1 ODPOWIEDŹ 1
  • 1849
  • 2707
@Michał8181
1) Spróbuj zresetować funboxa do ustawień fabrycznych.
2) Sprawdź ile sieci jest w okolicy i ustaw najmniej obciążony kanał Wi-Fi.
3) Jeżeli to uniemożliwia korzystanie z internetu zgłoś uszkodzenie modemu.
