- Oznacz jako nowe
- Zakładka
- Obserwuj
- Wycisz
- Subskrybuj źródło RSS
- Wyróżnij
- Drukuj
- Wyślij wiadomość e-mail do znajomego
- Zgłoś
Funbox 3.0 static IP + pfsense
Hello,
First of all sorry for asking the question in english but I don't know enough Polish to ask the question on Polish language.
I would like to know if is possible to get a static IP on the FunBox 3.0 and if so how to do it?
Moreover would it also be possible to have the FunBox connected to a pfsense and letting the pfsense deal with all the NAT?
Thanks in advance for your help.
Best Regards,
Pedro Cabral
- Oznacz jako nowe
- Zakładka
- Obserwuj
- Wycisz
- Wyróżnij
- Drukuj
- Zgłoś
The static IP is offered only for business customers. For none business customers the closest to get to static IP would be using DDNS like no-ip or change IP.
What would be the purpose of using pfsense? If you are asking about using your own router that kind of was possible with Funbox 2.0 (with separate ONT) with Funbox 3.0 I don't believe it is supported. If you need to get to inside your network from outside you would have to force ipv4 protocol inside Funbox 3.0 and use port redirect.
